problems starting up!!!
Old Dec 15, 2002 | 10:11 AM
B18C-RnVA's Avatar
New User
Default problems starting up!!!
I just got my new motor put it and everything was running pretty good. until last night i was chilling with some friends and went to start my car and it didnt start.
i would turn the key, all the accessories came on as usual such as radio and lights on the dash, but when i push in the clutch i can hear the starter "click" but wont fire up. someone was telling me that it could be my main relay or something like that...
can you guys help me please...
95 gsr with type R head if that helps
Old Dec 15, 2002 | 10:17 AM
digglewitz's Avatar
Default Re: problems starting up!!! (B18C-RnVA)
sounds like a bad starter to me.....check that first.....junk yards should have them for $50 or so
Old Dec 15, 2002 | 12:07 PM
B18C-RnVA's Avatar
New User
Default Re: problems starting up!!! (digglewitz)
if it was the starter, it shouldnt make that clicking noise when i push in the clutch correct??
Old Dec 15, 2002 | 12:19 PM
fastwanabe's Avatar
the starter solenoid makes the click, doesnt mean the starter itself is good.
Old Dec 15, 2002 | 12:43 PM
B18C-RnVA's Avatar
New User
Default Re: problems starting up!!! (fastwanabe)
alright i understand. thanks
Old Dec 15, 2002 | 12:49 PM
non-VTEC's Avatar
before you chuck out the old starter.........what flywheel are you using?
Old Dec 15, 2002 | 02:02 PM
B18C-RnVA's Avatar
New User
Default Re: problems starting up!!! (non-VTEC)
stock LS flywheel
Old Dec 15, 2002 | 02:14 PM
non-VTEC's Avatar
ok then it might be your starter after all.......
Old Dec 15, 2002 | 02:45 PM
ejprimo's Avatar
does it click more than once?
i would look at your battery.
Old Dec 15, 2002 | 03:27 PM
B18C-RnVA's Avatar
New User
Default Re: problems starting up!!! (ejprimo)
nope just one click everytime i push in the clutch
Old Dec 15, 2002 | 04:27 PM
3rdGteg's Avatar
Jump the battery and see if it starts; sometimes when the battery is low, the starter clicks even when your dash and everything else is lit.
Old Dec 15, 2002 | 05:25 PM
vtec.dc2's Avatar
had same thing happen, replace/charge battery, my car still started from jumpstart/pushstart... turns out my phonecharger was messing with the battery, cause same thing happen with new battery after 2 weeks, so i stopped leaving the charger in, and no problems since... weird how it worked out.
Untouchable13
Honda Civic (2001 - 2005)
15
Jun 10, 2009 01:55 PM
OfTheSun
Apr 6, 2006 10:29 AM
RiCE On IcE 2
Dec 15, 2005 10:38 AM
94si94cx
11
Jul 28, 2003 12:41 PM
94si94cx
Jul 28, 2003 09:37 AM
