PROBLEM: too much power going to battery
Old Jun 27, 2015 | 07:59 AM
slowesteg's Avatar
Default PROBLEM: too much power going to battery
im having a battery problem. at first the car ran fine then all of a sudden it dies and no power. checked the fuses and battery fuse was blown 80a. so i replaced that battery fuse with a extra 100a fuse i had laying around and now it seems like the battery is getting too much power because every time i go to connect the battery back up it sparks and basically melts the battery terminals (leaves scars where ever it touches). what could cause this?
i just install a JRSC and the alternator power supply bolt basically sits on the bottom half of the supercharger (the rubber piece is covering the alternator power supply bolt) u think this could be the problem or could it be the 100a fuse im using?
set up is a stock 92 si with d16z6 jrsc. grounds wires are connected (trans and valve cover)
Old Jun 27, 2015 | 10:56 AM
v4lu3s's Avatar
RTFM
Default Re: PROBLEM: too much power going to battery
You blow fuses from a short, putting a larger fuse in is likely to start a fire.
Old Jun 27, 2015 | 11:01 AM
burnoutboy's Avatar
The Credible Hulk
Check that rubber piece again, covering the alt bolt. Bet the engine moving wore right through it. That very likely IS the problem. Even if it didnt it's likely arcing to the super charger.
Old Jun 27, 2015 | 11:15 AM
cetcivic's Avatar
no one wants to hear the truth
Find the short before the firemen do!
Thoroughly check for any wires the are frayed , touching , bad grounds, etc.
Also check for damaged wires. Damaged wires will no longer flow current properly causing resistance.
Old Jun 27, 2015 | 01:49 PM
slowesteg's Avatar
i didnt even start the car for more than 30 sec. and that rubber piece was still in good condition. so it couldnt have wore it out already. the initial start up it was fine but the second start up this happened. just looking for ideas to check later.
but im gonna try to move the alternator piece tho. i looked at the JRSC instructions and says to clock it 90 degrees but hopefully i can with my alternator. ill go check it out in a bit, its to damn hot to do anything right now.
warmeister
Honda Civic (2001 - 2005)
Mar 6, 2019 10:58 AM
BrandonPell
Aug 30, 2018 11:03 AM
sdots24
Honda Motorcycles
Dec 16, 2011 09:41 AM
seamus657
Mar 6, 2009 08:47 PM
idteg
Nov 1, 2004 10:46 AM
