Problem with my AC
Old May 9, 2016 | 04:46 AM
kruiz15's Avatar
Default Problem with my AC
Hi
I have a problem with my acorrd 2004.
In my case nothing when I turn on the swith run, no air from vent duct, the compressor don't run ether, only the front fan condeser was run 5 sec and turn off again.
Can't you help me?
Thanks
Old May 9, 2016 | 12:38 PM
fcm's Avatar
fcm
Old Fart
Default Re: Problem with my AC
Are you saying your blower is not working, "I turn on the swith run, no air from vent duct"
A/C will not work if blower is not turning on. 94
Old May 9, 2016 | 05:10 PM
kruiz15's Avatar
Yes....blower, compresor don't run when I turn the switch to on, only the fan condenser run only 3 to 5 sec and turn off quickly.
Old May 10, 2016 | 02:33 PM
fcm's Avatar
fcm
Old Fart
As mentioned, if the blower will not turn on, A/C will not turn on.
A/C request is a ground from the A/C switch, the A/C switch gets it's ground from the blower switch, [any speed].
Check blower speed switch.94
jooky5
Jan 30, 2009 10:23 AM
akteamster
Sep 20, 2004 03:16 PM
