how to clean pistons?
Old Oct 5, 2005 | 12:24 PM
GSRCRXsi's Avatar
Default how to clean pistons?
ok well ive got these pistons and im pretty certain i need to clean them out before putting rings on them and installing them into the block. now my question is, how do i clean them? what can i use to get into the little grooves that the rings sit in?
Old Oct 5, 2005 | 01:36 PM
gsrious's Avatar
carb cleaner. works wonders.
Old Oct 5, 2005 | 02:42 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: how to clean pistons? (GSRCRXsi)
valvoline synpower carb and intake cleaner, and the end of an old ring will work fine
Old Oct 8, 2005 | 06:23 PM
1700anddroping's Avatar
Default Re: how to clean pistons? (japoneeZ)
i put mine in the washing machine....i just kidding man....
like the guys said above.
harv
Old Apr 21, 2007 | 08:31 PM
averyvm's Avatar
Default Re: how to clean pistons? (1700anddroping)
I have some old pistons that are out of the block, that I would like to clean up. Is paint thinner and carb cleaner kind of the same thing. They kind of smell the same and they're both very volatile. dont know if I spelled volatile right
averyvm's Avatar
bump for my dirty pistons
Old Apr 22, 2007 | 10:23 AM
averyvm's Avatar
Default Re: how to clean pistons? (averyvm)
bump for dirty pistons
Old Apr 22, 2007 | 10:16 PM
tony413's Avatar
look for my write up search for Cleaning Write up 56K beware
Old Apr 23, 2007 | 03:30 AM
D16Cowboy's Avatar
WHATEVER YOU DO, don't use a wire brush wheel or rotary power tool to clean the ring grooves. You need a specialty tool for that, it's called a ring groove cleaner. You can use a scraper tool (like a paint scraper tool) to clean the top of the piston. I'd beware of the outer edges of the piston top, because you don't want the edges to get rounded off whatsoever.
sk8board{Pete}
Oct 19, 2008 12:07 PM
GSRCRXsi
10
Oct 6, 2005 06:46 AM
hondaeg8
Jan 6, 2004 05:08 PM
sshaikh01
May 20, 2003 05:45 PM
Smoothy
Jan 9, 2003 02:40 PM
