pistons for b18 c5 with 83 or 84 bore
Old Apr 17, 2006 | 08:48 AM
bht72's Avatar
Default pistons for b18 c5 with 83 or 84 bore
hello
i will use in a b18 c5 engine pistons with a 83 or 84 mm bore.now it is 81mm.
but when i look,i dont find pistons for a integra.
do someone know wich piston i can use in this engine.i will have then a comp ratio about 11 and 12:1
i hope you understand my english.
Old Apr 17, 2006 | 05:59 PM
Muckman's Avatar
Moderator in Chief
Default Re: pistons for b18 c5 with 83 or 84 bore (bht72)
check out CP Pistons
Old Apr 18, 2006 | 06:33 AM
Chris22215's Avatar
Default Re: pistons for b18 c5 with 83 or 84 bore (Muckman)
i hope you are getting that block sleeved!
All You need is to buy some 83-84mm B series VTEC pistons from CP. Call Tom at Camp1320, he'll get you the right ones
Old Apr 18, 2006 | 07:46 AM
bht72's Avatar
Default Re: pistons for b18 c5 with 83 or 84 bore (Chris22215)
@chris22215
why do you think ,that i need a sleeved block.
the engine is not with boost then.
it is now 190 HP and then i will tune up only to 220-230 HP
NO turbo and NO supercharged
i think i can use the block normal.not sleeved!?
Ralf
Old Apr 18, 2006 | 09:06 AM
Chris22215's Avatar
if you're using a b20 block, then yes you can use stock sleeves. just be careful.
Old Apr 18, 2006 | 10:49 PM
bht72's Avatar
it is a b18c5.and i want to bore up from 81mm to 83 or 84 mm.is it possible with the original sleeves.
the car is not charged
Ralf
Old Apr 19, 2006 | 12:03 AM
johnnylawless's Avatar
no you can't, the stock sleeves are aluminum with a steel sleeve.
that inner steel sleeve will be paperthin @ 84mm, just get it sleeved if your going to go that large.
I had a c5 also but threw a rod thru the block.R.I.P
L8R
Old Apr 20, 2006 | 12:38 PM
bht72's Avatar
Default Re: pistons for b18 c5 with 83 or 84 bore (johnnylawless)
Thank you for the information
night
Jan 7, 2022 04:12 PM
GT500FTW
Engine Machining & Assembly
Jun 14, 2015 10:52 AM
I_got_your_honda
Aug 17, 2006 01:04 PM
jamessh1
May 28, 2004 04:30 PM
Smurfylude
May 1, 2002 04:39 PM
