piston/rod replacement
Old Nov 21, 2007 | 04:23 PM
integraRS-T's Avatar
Default piston/rod replacement
i heard peps talkin around of replacing the piston/rods without removing the engine by poping the head and tap the rods out by removing the oil pan, since i dont have the tools to pull the engine out i would take any tips bout it and what bout rehoning the sleevs is that somthin i could do any feedback is appreciated
Old Nov 21, 2007 | 04:38 PM
Sr420Det's Avatar
Yeah thats pretty much it. Take the head off, then the oil pan, and baffle. Then you will be looking at the crank where your rod bolts will be accesible.
Old Nov 21, 2007 | 04:47 PM
any other tips what about rehoning or checking my sleevs for sthrengt
Old Nov 22, 2007 | 10:01 AM
LastGenEK's Avatar
Default Re: (integraRS-T)
You could hone it if you have a hand held one with a drill. I would highly recomend a little hone if you are gonna put new rings in, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraRS-T &raquo;</TD></TR><TR><TD CLASS="quote"> checking my sleevs for sthrengt</TD></TR></TABLE>&lt; I dont know what that means But dont worry about it, I wouldnt mees with your sleeves just leave them alone.
But you should be able to do it I never have Good Luck
Old Nov 22, 2007 | 10:06 AM
Sr420Det's Avatar
I think he is talking about a line bore and thats something a machine shop would have to do with the block out of the car and completely stripped. You shouldnt have to worry about just use a hone tool that you attach to a drill. You dont have to spin it that much in the cylinder just enough to scuff it up.
Old Nov 22, 2007 | 11:02 AM
no i wasn't talkin bout a line bore just a little honing to buff out out the walls ,and i got another question when i get my pistons do i have to put on rhe rings on my self or they are already on another thing how many sets of rings are there on the piston
f1 vtec
May 30, 2006 08:27 AM
eMpAtHy
Jul 13, 2005 07:46 AM
Ekay Jay
Jun 2, 2005 07:16 PM
deSigi
Jun 4, 2004 09:29 AM
ScrapinSi
Jul 18, 2002 03:09 PM
