No oil? killed engine
Old May 29, 2006 | 01:02 PM
f1 vtec's Avatar
Default No oil? killed engine
Hi
Just wanted some info. If my engine oil disappeared from my car and subsequently the engine died. Would it be just the crank that i would have damaged in my engine or anything else with it?
Old May 29, 2006 | 01:12 PM
cjames235's Avatar
Default Re: No oil? killed engine (f1 vtec)
cant really tell till you take it apart...... could be a number of things..... spun rod bearings, spun crank bearings, piston locked in sleeve, cam ground into head, etc.
Old May 29, 2006 | 01:18 PM
f1 vtec's Avatar
Default Re: No oil? killed engine (cjames235)
would the rods any how be damaged??and what can i look for when i take it apart. Im not bothered about the cranck but im hoping the manley rods and CP pistons arnt damaged. and the fully built head
Old May 29, 2006 | 01:41 PM
cjames235's Avatar
if you spun a rod bearing then there is a very strong chance that rod is scarred up pretty bad and if you locked a piston up good enough there is a chance a that rod could be bent a lil bit also
sounds like its time to take it apart and see what damage is done......... how did it run out of oil in the first place? sounds very careless especially for such an expensive engine
Old May 29, 2006 | 01:43 PM
f1 vtec's Avatar
Damn im hoping that hasnt happened!!!
Old May 29, 2006 | 03:45 PM
Jago's Avatar
probably looking at everything brand new
Old May 30, 2006 | 06:04 AM
b18sihatch's Avatar
if you drop the oil pan you can check for slivers of meter from the bearings, did you car burn oil? reasons for the oil not there?
Old May 30, 2006 | 06:25 AM
f1 vtec's Avatar
Default Re: No oil? killed engine (b18sihatch)
Well i think it was burning oil but i think its not what caused it as it was only sipping small amounts. I bought a Moroso pan that was more or less stock size. I didnt think i required a different oil pick up but anyway i think thats what caused it.
Old May 30, 2006 | 08:27 AM
LSVTEC 91 Civic's Avatar
Banned
You weren't paying attention to your oil pressure?
If the big end rod journals are damaged, It's nothing an align hone can't repair. Any machine shop can repair them for you.
celliott92
Oct 22, 2014 04:45 AM
irishflame27
Oct 3, 2008 06:05 PM
whatafool
May 28, 2006 09:59 AM
rikawa
Dec 26, 2005 02:32 PM
Dyzee
10
Apr 28, 2004 11:56 AM
