pilot bearing
Old Apr 29, 2007 | 02:46 PM
hotrod99's Avatar
Default pilot bearing
I upgraded the clutch and flywheel on my 99 SI about a year ago with CC 4puck sprung and their lightweight flywheel....well I started getting weird gring noises and i took the tranny apart and found little metal shavings inside the trans. case.When I took the flywheel off the pilot bearing was torn up and 2 of the bearings fell out...My question is where do I order a new one...do I need to contact Competition Clutch?
Old Apr 29, 2007 | 05:12 PM
Chiovnidca's Avatar
Default Re: pilot bearing (hotrod99)
Pilot bearing, in the center of the flywheel? Most auto parts places should have em. Dealer should have em.
Old Apr 29, 2007 | 05:17 PM
Chiovnidca's Avatar
Default Re: pilot bearing (Chiovnidca)
Might be a good idea to check your input shaft bearing for noise/play while it's out of the car. A bad pilot bearing could put extra stress on it.
Dxs
Transmission & Drivetrain
Apr 10, 2015 11:59 PM
Nathan007
Jun 19, 2009 06:14 PM
skata89
Apr 14, 2006 02:45 AM
dave24
Oct 25, 2005 09:35 AM
1fastVX
Aug 22, 2002 05:43 PM
