flywheel?
Old Apr 12, 2006 | 07:15 AM
skata89's Avatar
Default flywheel?
k on the flywheel is there a washer between it and the clutch? bc when I pulled mine off there was a broken washer that and I don't where it goes .
Old Apr 12, 2006 | 09:31 AM
rgaray's Avatar
Default Re: flywheel? (skata89)
Looks like there is, but it doesn't look like a regular washer.
http://www.acuraparts247.com/p...ch=no
Old Apr 12, 2006 | 09:44 AM
CleanLikeJdm's Avatar
Hype-R Stalker
ah yeah, the pilot bearing? I think that's the name for it.
It where the tip of the spline from the trans goes.
Old Apr 12, 2006 | 10:17 AM
Tuan's Avatar
probably broken polit bearing.
Old Apr 12, 2006 | 12:50 PM
JDMC-Kamel's Avatar
Default Re: flywheel? (Tuan)
yup broken pilot bearing you replace those any ways when you replace the clutch.
Old Apr 12, 2006 | 01:45 PM
skata89's Avatar
Ok whats the difference from the pilet bearing and the throwout bearing? bc the washer is like not even half the size as the piolet bearing.
Old Apr 12, 2006 | 02:17 PM
Hype-R Stalker
Default Re: (skata89)
throw-bearing is Completely different, it's the piece on the clutch-fork that disengages the clutch.
Old Apr 12, 2006 | 02:34 PM
skata89's Avatar
then whats the pilot bearing?
Old Apr 12, 2006 | 02:42 PM
Hype-R Stalker
The piece that sits in the middle of the flywheel, it holds the tip of the trans spline in place.
Old Apr 13, 2006 | 05:33 PM
skata89's Avatar
Ok. well i have a lighten flywheel and with the clutch kit came a piolet bearing but it doesnt fit inside the flywheel. so do i have to go out and buy a new one?
Old Apr 13, 2006 | 05:53 PM
Hype-R Stalker
If it doesn't fit, then you need a new one, I wouldn't try it without.
Old Apr 14, 2006 | 02:45 AM
skata89's Avatar
ight thanks
greyEG
Jun 25, 2014 03:23 AM
Nathan007
Jun 19, 2009 06:14 PM
D16SiHatch
Apr 2, 2008 02:13 PM
The Flying Dutchmen
Sep 9, 2007 09:34 AM
1fastVX
Aug 22, 2002 05:43 PM
