flywheel noise
Old Oct 23, 2005 | 09:28 AM
dave24's Avatar
Default flywheel noise
i recently put in a l.w flywheel in my car.since i put it in there has been a whine comming from it.sounds like a supercharger which is pretty cool but should it be making this noise.tourqed all bolts as specified etc
thanks.
Old Oct 25, 2005 | 09:18 AM
dave24's Avatar
Default Re: flywheel noise (dave24)
anyone have any info.
Old Oct 25, 2005 | 09:19 AM
Keebler's Avatar
Did you replace the input shaft bearing? Throw out bearing? Does it whine only when you put the clutch in, or at idle with no load?
More info
Old Oct 25, 2005 | 09:23 AM
dave24's Avatar
only whines under load and i did not replace the shaft bearing.
Old Oct 25, 2005 | 09:24 AM
Keebler's Avatar
Default Re: (dave24)
Does it whine with the clutch in or out?
Should have replaced both bearings while you were in there
Old Oct 25, 2005 | 09:27 AM
dave24's Avatar
only whines when the clutch is out either under accel or decel.the engine is relatively new only 70k miles and previuos owner was an o.a.p until 68k miles,so i didnt see any reason why i should have to change the bearings.
Old Oct 25, 2005 | 09:31 AM
Keebler's Avatar
Its just a good habit, if you have something torn down like that to replace wearable items like bearings. Just something Ive always done, not necessarily a "have to" thing.
As for the whine, did you relube the input shaft going back into the bearing? Did you accidently damage the bearing moving it from one flywheel to the other? Did you put tranny oil back in? Dumb question I know, but it has to be asked.
Old Oct 25, 2005 | 09:35 AM
dave24's Avatar
yes to all,except for damaging anything
Dxs
Transmission & Drivetrain
Apr 10, 2015 11:59 PM
Nathan007
Jun 19, 2009 06:14 PM
hotrod99
Apr 29, 2007 05:17 PM
skata89
Apr 14, 2006 02:45 AM
1fastVX
Aug 22, 2002 05:43 PM
