overheating problem
Old Aug 18, 2004 | 01:07 AM
mR. Vash's Avatar
Default overheating problem
my car is overheating... i changed the thermostat and flush'ed it. i have a JDM h22 in a 93 civic hatch, using an integra radiator. this has never happended before, the radiator erounded <--- (check spelling) from where the upper radiator house connects to the radiator i dont know if that would cause over heating but it has never over heat'ed untill that... any help would be greatly appreciated. thanks
Old Aug 18, 2004 | 04:36 PM
doublejz's Avatar
Default Re: overheating problem (GsRdHatcH)
maybe you have air in the cooling system, try bleeding it.
Your head gasket might be starting to kick the can
Old Aug 18, 2004 | 05:11 PM
Crazydave's Avatar
Default Re: overheating problem (doublejz)
are you loosing coolant?
do your fans turn on and off?
Old Aug 19, 2004 | 01:10 PM
mR. Vash's Avatar
Default Re: overheating problem (Crazydave)
the fan turns on, but it still doesnt help. I am losing coolant. When i drive for a long period of time the coolant boils out of the resevior really hot just coming out on the top. Besides that there isnt any leak anywhere. By the way I've bled it and still doesnt work.
Old Aug 19, 2004 | 04:26 PM
murtnabila's Avatar
head gasket or water pump...on civics this happens a lot and it's usually water pump. look around water pump see if you see any leaks or slight corrosion from a small leak or wutnot
Old Aug 19, 2004 | 04:55 PM
mR. Vash's Avatar
Default Re: overheating problem (murtnabila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murtnabila &raquo;</TD></TR><TR><TD CLASS="quote">...on civics this happens a lot and it's usually water pump. </TD></TR></TABLE>
im thinking it might be the head gasket ....by the way the CX is a H22a
Old Aug 20, 2004 | 01:30 PM
doublejz's Avatar
well, if the coolant is coming out of the reservoir then its most likely a bad head gasket. The air in the cylinders is leaking through the bad spot in the head gasket and forcing the coolant out the easiest way, which is the reservoir cap.
Old Aug 20, 2004 | 03:24 PM
mR. Vash's Avatar
i just put in some ceramic head gasket sealer and hopefully that works.
Old Aug 20, 2004 | 04:46 PM
senpai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsRdHatcH &raquo;</TD></TR><TR><TD CLASS="quote"> the radiator erounded &lt;--- (check spelling) from where the upper radiator house connects to the radiator</TD></TR></TABLE>
well, try a new radiator
54
Nov 20, 2008 12:39 AM
civic_22
Jun 16, 2008 01:01 PM
hmtcrxsir
14
Aug 10, 2006 04:12 AM
nels415
Sep 21, 2005 12:27 PM
Gabe_
12
Jun 13, 2003 02:47 AM
