proper way to burb radiator??
Old Aug 10, 2009 | 12:11 PM
ctr32's Avatar
Default proper way to burb radiator??
hey guys...i just recently put in a new 160f thermostat..and i think theirs some air pockets..what is the proper way to burb it? Ive read all different kinds what is the best?
Old Aug 10, 2009 | 12:19 PM
SpoolnG2's Avatar
Default Re: proper way to burb radiator??
Take the radiator cap off...start the car...and let it run through its heat cycle a few times/until you stop seeing bubbles coming up. Then check to make sure everything is topped off to where it should be. Thats how I just did mine after changing a coolant hose. No problems
Old Aug 10, 2009 | 12:21 PM
96 GSR-T's Avatar
Why are you running such a low temp thermostat?
I always fill the rad all the way up, start the car and let it fully warm up the turn the heater on (if equipped) and add more coolant until its filled up completely, then I shut the car off and let it cool and repeat the process a few times.
Old Aug 10, 2009 | 12:28 PM
ctr32's Avatar
engine is overheating a little bit..have to get a bigger fan...
Old Aug 10, 2009 | 12:29 PM
ctr32's Avatar
ok cool ill try that
Old Aug 10, 2009 | 12:56 PM
ctr32's Avatar
just did it this way with the cap off right? at all times? when it warmed up the water was at the top of the radiator then saw some little bubbles then one huge bubble and it dropped so im gonna do it coupe more times
Old Aug 10, 2009 | 02:32 PM
bigD's Avatar
sometimes it helps to lift the front of the car up to get all the air out.
Old Aug 10, 2009 | 02:47 PM
96 GSR-T's Avatar
yes make sure the cap is off, I do it several times before I eventually get it all out. I was also repeating the process roughly every tankful but I always give the car a once over before driving it, so while it was warming up every now and the I bled the air out of the system..... I got a good burp every time I pulled the cap off.
Old Aug 10, 2009 | 02:55 PM
ctr32's Avatar
yeahh ill do it again..how long do u wait to do it again i mean till its fully cold or wait like 1 or 2 hours?
Old Aug 10, 2009 | 03:01 PM
96 GSR-T's Avatar
I just wait until the coolant needle reaches C, never really took me longer than an hour.....
Old Aug 10, 2009 | 03:03 PM
ctr32's Avatar
k
1CiViC1
20
Dec 24, 2016 07:35 PM
EGcivic_95
31
Jan 29, 2011 06:09 PM
irideslammed5021
Aug 29, 2006 07:47 AM
budget
Apr 10, 2005 12:23 PM
SolidSpruce
Oct 2, 2003 06:42 AM
