Old gas, need to syphon.
I just had an idea and was wondering if it would work. My car's been sitting for around 8 months and I need to syphon the gas. Could I just run the end of the fuel line into the gas can and turn the key, letting the fuel pump prime and pump all the gas out itself? My engine isn't in yet so I figured this might be easier at this point. I know it would be almost as easy to syphon it from the fill, but I'm just curious.
As long as you aren't stirring up 8-month-old crud & plugging up your pickup strainer, then yes. It sounds pretty easy to take the fuel line off from the filter & stick it into a gas can... If you run the fuel pump by jumpering something with a screwdriver, just don't set the gas can on fire.
my car was sitting in my garage for 6-7 months until i got the motor all hooked up and it started up just fine..i dont think you have to do all that..maybe put some kind of octane booster in before you start it if you want..
Hondaisok
Sep 27, 2010 09:30 AM
Hard2Find
Aug 16, 2004 08:47 PM
