Oil seep
Old Sep 13, 2005 | 12:34 PM
SPOOLINmatt's Avatar
Default Oil seep
i have a oil seep im guessing from the headgasket directly under the dizzy. ive had several people that have had this leak at some time or another. my engine is built, 6000 miles ish. I just now retorqued last night i dont know if it has worked yet because im pulling the motor and putting it in another car. its torqued to 75lbs on AEBS studs. any remedies to stop this leak.
Old Sep 13, 2005 | 11:46 PM
Takumi Fujiwara's Avatar
Default Re: Oil seep (SPOOLINmatt)
Are you positive it's your headgasket? I assume that's why you retorqued your head studs...
I would check the vtec spool gasket (vtec solenoid/oil pressure)... maybe even the distributor 0-ring.
sprignig92_eg
Feb 2, 2011 11:43 PM
macrohard
Aug 11, 2006 05:15 AM
d16vteceg
Jul 8, 2006 09:36 PM
Pandahatch
May 25, 2004 08:10 AM
2k2silvertype-s
Dec 20, 2002 07:04 AM
