VTEC problems
Old Jun 30, 2006 | 09:05 AM
d16vteceg's Avatar
Default VTEC problems
Well my vtec is going in and out, one second vtec will kick in and the next minute it won't. I seem to have a small leak in my vtec solenoid, probably from my gasket, could that be the reason I am losing vtec? Should I just get a new solenoid? Are there any other possibilities it could be? Please lmk asap.
Old Jun 30, 2006 | 09:24 AM
qfast817's Avatar
Default Re: VTEC problems (B18chatch83)
check the oil, you might be low
Old Jun 30, 2006 | 09:32 AM
DC2TEGGA-GSR's Avatar
Default Re: VTEC problems (qfast817)
best bet is what he said the oil, its a great way to let u know ur running low
Old Jun 30, 2006 | 09:35 AM
Lauj87's Avatar
if not your oil then i would take off the solenoid and check it.
Old Jun 30, 2006 | 09:54 AM
2000GSR2432's Avatar
its your oil
Old Jun 30, 2006 | 10:12 AM
d16vteceg's Avatar
well I just had an oil change done, but I could be low because of the leaking, so get another oil change, get another gasket and I'll be good to go?
Old Jun 30, 2006 | 10:29 AM
SlammedDC2's Avatar
Semper Fidelis
You don't necessarily need another oil change, just check your oil. If it's low add some. Next time you change your oil change your VC gasket and oil pan gasket just to be sure. But you need to go outside and check your oil right now so you can narrow down the problem. You don't want to be running around with low to no oil in your motor. That's when things start to knock.
Old Jun 30, 2006 | 12:46 PM
d16vteceg's Avatar
Default Re: VTEC problems (SlammedDC2)
Alright so what happened is so far I remembered that I had stripped one of my valve cover nuts and it pretty much broke the bolt, I found the leak of my oil and it is from that, it is actually building up enough pressure to shoot out at my hood and make it onto my front bumper, I bought the new bolt needed and hopefully this will fix the problem.
Old Jul 1, 2006 | 04:05 PM
d16vteceg's Avatar
Well I replaced both of my vtec solenoid gaskets and that fixed my oil leak problem but now I am not getting any vtec at all, should I replace my solenoid all together?
Old Jul 8, 2006 | 09:36 PM
did you add more oil? did you plug the solenoid back in? just becuase you fixed the leak doesnt mean it wont be low, not bangin on ya but a lot of simple fixes like that are overlooked.
davey5300
May 7, 2010 06:01 PM
krazy one
Jan 30, 2008 12:50 AM
jdm ek9 101
May 10, 2007 11:30 AM
Dr Wylee
Apr 19, 2007 02:23 PM
stringcheese840
Jun 22, 2005 02:28 PM
