Oil Problem
Old Feb 15, 2006 | 08:22 AM
gman1's Avatar
Default Oil Problem
Hi , I am new to the this forum, I have a 96 honda civic Si with an H22a from a 95 prelude it's turbo. She blows blue smoke on start up and after about 30 minutes of driving it fouls out #3 spark plug, I did a compression test and it's great I also did a leak down and it was fine too, the other thing I checkd was the turbo and there is no oil in my intercooler pipeing, my thoughts are that it may be a valve seal, cause when I put new plugs in it the car runs awesome for about 30 minutes to an hour depending on how I drive it, just wondering if anyone has had this problem befor with valve seals any info would be great, thanks
---Garth
Old Feb 16, 2006 | 04:37 AM
FastGsr95's Avatar
Default Re: Oil Problem (gman1)
I WOULD CHECK THE VALVE LASH FIRST IF THE VALVE LASH IS TO TIGHT THEN IT COULD BURN A VALVE
Old Feb 16, 2006 | 04:38 AM
FastGsr95's Avatar
Default Re: Oil Problem (FastGsr95)
AND CHECK THE TIMING BELT OR THE DISTRUBITOR
sleepercivic88
Apr 10, 2009 05:57 AM
ripper115
Jun 28, 2006 04:56 AM
Tony_EM1
Apr 27, 2005 06:42 PM
RTW DC2R
Mar 19, 2004 09:05 AM
92slowvic
17
Jul 23, 2003 04:50 PM
