Oil pressure sender need to be grounded?
Old May 26, 2003 | 06:09 PM
B18EG6's Avatar
Default Oil pressure sender need to be grounded?
Howdy... I moved my oil pressure sensor to a tee on the firewall. I noticed today my light flickered once or twice as I was driving (not turning) even though I just put almost 5 quarts of fresh new oil in it a mere hour ago when I changed my oil.
Wow sorry for the runon. Do I need to ground the sender at all?
here is a picture of what i mean.
Old May 26, 2003 | 06:18 PM
MADEINIRAQ's Avatar
Default Re: Oil pressure sender need to be grounded? (B18EG6)
groun the sender
Old May 26, 2003 | 06:54 PM
Lamchop0000's Avatar
no you dont need the sender. but its good to know if your ever out of oil. if you have a oil pressure gauge you can lose the pressure switch if you want, nothing will happen. just you wont have an oil light anymore. it doesnt interfear with the ecu.
B18EG6's Avatar
Default Re: Oil pressure sender need to be grounded? (madeiniraq)
Can I just put a washer in between the sender and tee, solder a wire onto it, and ground it on the body?
eric416
Oct 9, 2008 04:03 PM
preludefien
Apr 18, 2007 06:28 PM
BACKintheDA
Jul 12, 2005 01:05 PM
livelife46290
Jul 14, 2004 05:15 AM
96b18c
Feb 23, 2003 10:45 PM
