View Poll Results: ?
Cover it with Hondabond
28.57%
Just a little Hondabond in the corners like the book says
64.29%
No Hondabond at all
7.14%
Voters: 14. You may not vote on this poll
Oil Pan Gasket
Old Nov 11, 2009 | 12:36 AM
InvaderTrax's Avatar
Default Oil Pan Gasket
Planning to replace mine soon and wanted to know how you guys do it and what methods work best on steel oil pans
Old Nov 11, 2009 | 04:36 AM
mec. pedri's Avatar
Default Re: Oil Pan Gasket
after cleaning the oilpan (the surface the gasket goes on) and block install the gaSKET and torque according to helms manual
if both surface are clean and dry you will not have any issues
i never use honda bond on my oilpan gaskets and they never leak!!!
Old Nov 11, 2009 | 05:35 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
I always use hondabond (or the equivalent) and they never leak.
Old Nov 14, 2009 | 12:17 AM
4thgenHB157's Avatar
i use ultra grey on the corners and a dap on the alignment holes. never leaks. i have left it dry with no leaks, but after a while it gets hard and will leak around the alignment holes, which is why i know add some there
Old Nov 14, 2009 | 04:11 AM
KWayRacing's Avatar
I use a decent run down both ends into the turns
Old Nov 14, 2009 | 05:54 PM
Hybrid96EK's Avatar
anyone who votes to cover the complete gasket with Hondabond is just being a jackass. Follow the manual. Engineers know what they are doing.
Old Nov 18, 2009 | 04:21 PM
anothersickhatch's Avatar
what makes these guys jackasses?
Old Nov 18, 2009 | 05:03 PM
JDogg's Avatar
have you ever taken apart a motor that was built by one of these jackasses? fn RTV everywhere in the engine.
its not needed, do it just like the manual says, make sure to torque the bolts properly, then go over them again as they will loosen up as you get them all tight.
Old Nov 18, 2009 | 06:55 PM
ah. good point. i never thought about that.
Old Nov 18, 2009 | 07:12 PM
Scott_Tucker's Avatar
On paper gaskets, I always use gaskacinch and anywhere two castings meet or in corners i put a dab of RTV. At work I just use black permatex because my boss is cheap and that is what he buys. On my own stuff I use Toyota black RTV, it is the best RTV made.
Civicnewbie123
Mar 10, 2015 12:38 PM
HDsol1996
Oct 27, 2013 10:02 PM
teler86
14
May 18, 2006 05:18 AM
jadugartir
Dec 30, 2005 02:09 PM
1.8
23
Mar 17, 2005 07:45 PM
