ABS ring on wheel hub
Old Nov 13, 2009 | 04:46 PM
racingcrx's Avatar
Default ABS ring on wheel hub
car is a 93 accord ex sedan. I just changed out the right rear wheel bearing and the new one does not have the ABS ring on it. and I couldn't get the old one off. So my question is.
1.) Is there a way to get the ABS ring off the old HUB?
2.) Where can I buy this ABS ring?
Old Nov 14, 2009 | 06:31 AM
racingcrx's Avatar
Default Re: ABS ring on wheel hub
BUMP! anyone know?
Old Nov 16, 2009 | 10:50 AM
racingcrx's Avatar
bump does anyone know?
Old Nov 18, 2009 | 12:20 PM
racingcrx's Avatar
54 views and no replys?
Old Nov 18, 2009 | 12:42 PM
CRX T-Si's Avatar
http://www.harborfreight.com/cpi/cta...temnumber=3979
This bearing seperator works really good if you have a press.
If not then try to rent this from autozone.
http://www.autozone.com/autozone/cat...&brandName=OEM
Its called OEM / 3 in. 2 Ton 3 jaw posi lock puller.
Spray some PB blaster on the ring to get the rust around it loose.
Old Nov 18, 2009 | 04:20 PM
worlds-slowest-EG's Avatar
if the ring won't come off then you got the wrong part. that's why you always match up the part before you install it and have to try to return a "used part"
Old Nov 18, 2009 | 10:21 PM
racingcrx's Avatar
that was the only part they had. and I have the bearing separator on it now. and I just got a press. so i will try. but i might need to get a new bearing separator since the threads on it looks to be stripped
hondatuner020
Oct 21, 2014 09:39 AM
alexg103
Feb 23, 2010 11:16 AM
nico91civic
Nov 12, 2008 09:04 AM
youdontknowmeeither
Dec 20, 2006 08:50 PM
saber1
Nov 3, 2004 07:53 AM
