ODB2 Code Reading Question?
Old Jun 5, 2005 | 05:47 PM
ORcivicsi's Avatar
Default ODB2 Code Reading Question?
Noob question. Is it possible to flash the CEL code on a 2000 civic si stock computer. I cannot find a two plug connector. Someone help.
I usually go to autozone and use their diagnostics tool. But right now they don't have one.
Old Jun 5, 2005 | 08:53 PM
ORcivicsi's Avatar
Default Re: ODB2 Code Reading Question? (ORcivicsi)
Old Jun 5, 2005 | 10:55 PM
Katman's Avatar
yeah you can...
look under the passenger side section of your dash, to the right of your glove box; using a flashlight you should see a green rubber block stuffed up under your dash, pull this down and pull out the smaller blue plug and jump it with a paperclip while your check engine light is on and the check light should start blinking the cel code(s).
hows that for a run-on sentence!
Here's a list of ecu codes:
http://ecu.ff-squad.com/tech.ecu.codes.htm
and here's a list of OBD2 P codes:
http://ecu.ff-squad.com/tech.ecu.codes-p.htm
Old Jun 7, 2005 | 10:14 AM
ORcivicsi's Avatar
Default Re: ODB2 Code Reading Question? (Katman)
Pictures?
Old Jun 7, 2005 | 02:41 PM
tuckin15s_8315's Avatar
yeah it is right under the passeneger side by the glove box like he said above it shouldnt be hard to find but u might have to lay on the floor to see it if u have a haynes or helms manual it will tell u exactly how to do it.
Old Jun 8, 2005 | 01:04 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ORcivicsi &raquo;</TD></TR><TR><TD CLASS="quote">Pictures?</TD></TR></TABLE>
only pic I have online is this one:
TouringAccord
Oct 12, 2004 07:20 AM
DeDonDeRosa
Oct 2, 2004 05:22 PM
Dino_D
Mar 10, 2004 11:03 AM
uszcrx
Aug 16, 2003 09:25 PM
Log4n
Mar 15, 2003 05:11 AM
