obd2a and obd2b differences in sohc distributor?
Old Feb 9, 2004 | 02:31 PM
tominos's Avatar
Default obd2a and obd2b differences in sohc distributor?
so what are the differences if any between the 96-98 dizzy's and the 99-00 dizzy's? are the internals the same? plugs same? can i put a 99-00 dizzy on my 97 civic?
Old Feb 9, 2004 | 02:38 PM
MrTodd's Avatar
Default Re: obd2a and obd2b differences in sohc distributor? (tominos)
I don't think there are any differences...
Old Feb 9, 2004 | 06:53 PM
tominos's Avatar
Default Re: obd2a and obd2b differences in sohc distributor? (MrTodd)
any other opinions?
Old Feb 9, 2004 | 08:06 PM
Kataku2K3's Avatar
Internally OBDI, OBDIIa, and OBDIIb are all EXACTLY the same... The differences you'll see are in the connector... I know for a fact that all OBDI distributors had 2 connectors, where as some of the '96-2000 were single plug and some of them were dual... This really isn't that big of a deal as you can just cut and solder different connectors... From everything that I've seen (and I may be wrong cuz I don't work with SOHC's that much) it seems as tho all of the single connector '96+ Civic's have been DX/EX's and I've seen a few CX's online with the 2 plug connectors... Correct me if I'm wrong but I do know for a fact that there are two different styles of '96-2000 connectors...
Old Feb 9, 2004 | 10:58 PM
tominos's Avatar
Default Re: obd2a and obd2b differences in sohc distributor? (Kataku2K3)
kool, thanks for the reply. just what i was lookin for.
Old Feb 10, 2004 | 05:06 AM
EE_Chris's Avatar
99 Cx hatch - D16Y7: Distributor only has one plug.
I don't think 96-00 used 2 connectors for the dizzy; Kataku2K3 - Had you seen a 96-00 with 2 dizzy connectors?
Old Feb 10, 2004 | 05:48 AM
Kataku2K3's Avatar
Default Re: obd2a and obd2b differences in sohc distributor? (EE_Chris)
Cool well that's good to know... Maybe it is year dependant but I HAVE seen some OBDII engine harnesses with 2 plug dizzy connectors (that's why I brought it up)... I actually just did an EJ's harness last week that required me to change to the single connector (which I prefer) and I've also had people on H-T show me pics before and ask questions... The only reason that I brought up the possibility of being a CX is because every DX that I've worked with has had a single dizzy connector and of all my one piece ('96-2000 Civic) engine harnesses I don't label which ones are CX and which ones are DX... Again, it shouldn't be that big of a deal, if you have to swap dizzy connectors or the plug(s) on the engine loom then just do that and you'll be fine...
viet_boi_racin
Apr 11, 2011 04:29 AM
SpoonfedCivic
Feb 10, 2011 07:48 PM
Civiclx
19
Apr 4, 2004 06:39 PM
tominos
Feb 12, 2004 08:56 PM
trbob16a
Jul 12, 2002 05:08 PM
