obd2 engine harness conversion
Old Mar 29, 2006 | 08:25 AM
b20vtech's Avatar
Default obd2 engine harness conversion
anyone here knos how to run a obd2 civic dx engine harness on a 92 eg race chasis? how to get power to the ecu and all? how to make everything work? need some advice.....
Old Mar 30, 2006 | 01:26 AM
b20vtech's Avatar
Default Re: obd2 engine harness conversion (b20vtech)
someone??
Old Mar 30, 2006 | 04:57 AM
EE_Chris's Avatar
Do you have a Helms manual?
Old Mar 31, 2006 | 07:49 AM
b20vtech's Avatar
Default Re: obd2 engine harness conversion (EE_Chris)
no.....do i need one?
Old Mar 31, 2006 | 09:06 AM
EE_Chris's Avatar
Anyone who works on a Honda, should have one. It's the factory service manual found at the dealership.
You don't want to use an OBD2 Civic engine harness in a 5th gen chassis, that much is for sure.
Old Mar 31, 2006 | 06:55 PM
b20vtech's Avatar
my car has no wire harness.......so i need the obd2 civic one piece engine harness from the egine to the ECU.....much easier than using a obd1 engine harness which is two piece and it runs from the head light,fan ect,ect and egine to the ecu......but i dont kno if it will get power to the ECU because im also not running a FUSE box.....it's a straight up race chasis that needs to be rewire all over again from scratch......u get it?
Old Apr 1, 2006 | 04:36 PM
EE_Chris's Avatar
If you have a Helms, you'll have the wiring diagram. You'll then be able to provide power to the ECU because you'll know what wires are used to do it. But the harness that runs from the engine into the cabin isn't all there is to making the engine wiring complete. So you're gonna need the Helms at some point.
pnapolitano29
Nov 26, 2014 07:30 AM
CivicB18C1
Jun 13, 2008 05:47 PM
advan414
Feb 13, 2008 11:51 AM
everlasting1832
Jan 4, 2006 09:38 AM
