OBD2 car OBD1 motor
Old May 20, 2003 | 05:52 PM
B18C1 '96 Coupe's Avatar
Default OBD2 car OBD1 motor
what all do I need?
I have OBD1 motor, OBD1 ECU, OBD1 harness. what else do I need?
Old May 20, 2003 | 10:53 PM
bitzbp's Avatar
Default Re: OBD2 car OBD1 motor (B18C1 '96 Coupe)
Good luck getting help....I'm trying to put a obd2 motor and engine harness in a obd1 car with an obd1 ecu and obd1 chassis harness and I can't get a straight answer as to how to make them work together.
Old May 21, 2003 | 12:37 AM
3rdGteg's Avatar
what type of motor and car. You can possibly use ur existing obd2 harness with an obd2 distributor, etc. Some more info about the potential swap and chassis would help....
Old May 21, 2003 | 05:06 AM
Default Re: OBD2 car OBD1 motor (3rdGteg)
The motor is a D16Z6 the chasis is a EJ8.
The harness I have now is converted for the GSR motorwith custom plugs made for teh GSR sensors. so I dont think using the exsiting harness is an option.
Old May 21, 2003 | 05:08 AM
ERA's Avatar
ERA
use SEARCH don't bring old **** back to the forum
Old May 21, 2003 | 06:55 AM
Default Re: OBD2 car OBD1 motor (delslo26)
I did search.I know the search feature very well thanks. But things that I found were on how to make your ODB1 car OBD2. Maybe some help. not critisizim (SP).
Way to be an ***
Old May 21, 2003 | 07:33 AM
wickedEFguy's Avatar
since your in clearfield give cortney a call at modern garage, he swapped a Z6 into a 98 coupe (cody's car if you know who I'm talking about)....Just ask him and he should be able to give you some good advise.
what engine harness are you using also are you going to be using the Z6 harness? have you tried transferring the the GSR harness to the Z6 and just getting new plugs and a jumper harness and converting to OBD1?
Modern Garage
262-4605
Old May 21, 2003 | 07:42 AM
Default Re: OBD2 car OBD1 motor (Ninja_Jc7)
I havent tried that But I will give them a call.
Old May 21, 2003 | 02:25 PM
anyone else have any sugestions?
diviznrider
13
Apr 19, 2019 01:38 PM
TravisBiggie
May 24, 2012 07:13 AM
wacohnda_rider
Aug 18, 2009 10:19 PM
RedlinedEG
Mar 12, 2008 08:35 PM
vtecftw
Aug 11, 2007 11:15 AM
