Ctr pistons in GSR. No notches on ctr piston.
Old May 21, 2003 | 02:12 PM
slowdx's Avatar
Default Ctr pistons in GSR. No notches on ctr piston.
Ok i noticed in my stock gsr pistons there are little notches that seem to be where the oil squirters go through. The CTR pistons dont have these. Do i need to "make" my own notches or is it not neccesary?
I didnt even think the piston went down far enouhg to get that close to the squirters. I just want to make sure.
Also, My oil squirter was bent about 1/8 inch to the right, can i just bend it back, or will it damage it, or is it ok moved over a little like that? Will it hit the piston or rod where it is? Should i wait until i get the rotating assembly back in and crank it by hand and see if it touches or if it gets close enough to touching it?
Thanks.
Old May 21, 2003 | 02:24 PM
Spids5's Avatar
Don't judge or question
My CTR pistons have three on each side where the rings go and two on the bottom of the piston. I read that the type r pistons have the bottom holes for the oil squirters while the other b-series pistons do not. Where are the ones on your gsr pistons? You should put up some pics to show exactly what you are talking about.
Old May 21, 2003 | 02:28 PM
slowdx's Avatar
Default Re: (spids5)
Ill try to get some pics up tonight, a friend is borrowing the camera. Ill try to explain what i mean.
at the bottom of the piston where it kinda teardrops down on each side, there is a tiny little notch on one side of the gsr piston. I figured it was to give the under piston oil squirters a little more clearance. I jsut wondered whyt he CTR piston didnt have the little notch.
I think we are referring to 2 different things. Ill get pick up tonight hopefully.
AllMoTaKid
May 15, 2006 11:14 AM
Po0r LiTTle CoUpe
Jan 1, 2006 05:07 PM
Eaglekper0046
Aug 3, 2005 07:18 PM
10000rpm
Sep 20, 2004 02:27 PM
oMek
Jan 10, 2004 10:49 AM
