O2 Sensor problem
Old May 16, 2005 | 01:11 PM
apok's Avatar
Default O2 Sensor problem
OK, I've been having a wierd O2 Sensor problem lately.
My car has been throwing a Code 1 (O2 sensor) which turned out to be a P0132 (O2 Sensor High Voltage Bank 1 Sensor 1) code.
The O2 sensor was out, though, so I went and got a new one.
I changed the O2 sensor and made sure there was no ungrounded wires, but the code is still being thrown. It messed up my idle a bit, and the CEL is bothering me. None of my friends (I am part of a shop that pretty much specializes in Honda performance) can figure it out, and I don't want to have to shell out money for a technician to take a look and not fix anything. I'll do that myself. Does anyone have an idea of what is going on? Where should I look to find problems with a source for the high voltage problem. New O2 sensor, and changed the IAT sensor which had also gone out.
Old May 16, 2005 | 01:19 PM
no2unenolife's Avatar
did u reset the ecu?
Old May 16, 2005 | 06:02 PM
97tegGS's Avatar
Default Re: (no2unenolife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2unenolife &raquo;</TD></TR><TR><TD CLASS="quote">did u reset the ecu?</TD></TR></TABLE>
What he said. You might have to clear the codes out before it actually takes effect.
Alos did you replace the first or second o2?
Old May 16, 2005 | 07:11 PM
apok's Avatar
Default Re: (97tegGS)
Reset the ECU several times so the car doesn't die while idling ever. I replaced the catalytic O2 sensor several months ago, and just recently replaced the header O2 sensor. I'll check and make sure nothing got torn up on the second sensor, but I doubt it.
Old May 16, 2005 | 07:18 PM
Drian's Avatar
I had a similar problem. After installation, I reset the ecu and or undid the negative cable.
Old May 16, 2005 | 09:52 PM
CD7power's Avatar
Default Re: (Drian)
did u try clearing the codes with a obd scanner?
claytonsmith
10
May 16, 2006 12:01 PM
cu3tip
Oct 18, 2004 09:45 PM
cu3tip
Oct 18, 2004 08:26 PM
CereaLand
Jun 30, 2004 12:01 PM
johnzm
Jul 7, 2002 05:19 PM
