o2 Sensor idea
Old Sep 24, 2003 | 04:02 PM
Smith Wise's Avatar
Default o2 Sensor idea
Setup: 99 Honda Civic ej6
Engine: d16y7, i/h/e
I'm currently getting code 41 from one of my o2 sensor plugs. Which ever sensor I plug the the "bad" plug into gets the malfunctioning code 1 or 2. I was thinking that if I got an obd-2 to obd-1 ecu conversion harness & obd-1 ecu that I would only have to run with one o2 sensor. I figure with only one o2 sensor, and one good plug I would be fine.
Anybody have any ideas about my theory?? Any tips for fixing the existing problem?? I believe it has a short in one of the black heater wires. Should I run a ground from both the wires to a 12 volt?? Any help/advice would be appreciated.
Old Sep 24, 2003 | 07:34 PM
Nameless RB26's Avatar
Default Re: o2 Sensor idea (Jswpstdoff)
You can pick up another 02 sensor on here for probly 20$....
Or you can just convert to OBD1 for around 375$....
your choice
Old Sep 25, 2003 | 04:33 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jswpstdoff &raquo;</TD></TR><TR><TD CLASS="quote">... Any tips for fixing the existing problem?? I believe it has a short in one of the black heater wires. Should I run a ground from both the wires to a 12 volt?? Any help/advice would be appreciated.</TD></TR></TABLE>According to my '95, the ECU wants to see somewhere from 10 to 40 ohms, isolated from ground. So it throws 41 if it sees either an open, short, or any connection to ground.
Old Sep 25, 2003 | 11:38 AM
Smith Wise's Avatar
Default Re: o2 Sensor idea (Nameless EJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">You can pick up another 02 sensor on here for probly 20$....
your choice</TD></TR></TABLE>
I've already changed them both, for way too much
O2 woes
jdm89crxhf
May 18, 2013 02:26 PM
JasinC19
Oct 11, 2007 09:47 AM
oh_lee_allen
Apr 29, 2007 01:25 PM
integranator
Jul 16, 2003 09:46 PM
