dissable o2 sensor!?
Re: dissable o2 sensor!?
well i have a gsr swapped eg in obd1 p72 throwing code 41 bad o2 sensoe i have replaced the o2 sensor 3 times an dcek still stays on
Technical Hero
Year, make, model, trim?
https://honda-tech.com/forums/hybrid-engine-swaps-18/ls-swap-civic-code-41-a-3124881/
code 41 is o2 sensor heater.. how many wires are coming out of your o2 sensor? if your p72 is a virgin, it will be looking for 4 wires (if it's obd1.. which I'm assuming it is). some EGs come with a 1-wire, 2-wire, etc o2 sensor so if you have a 2-wire o2 sensor, all you're sending out is power and ground without the heater part.
either A) get a 4-wire o2 sensor and wire it up with the correct ECU pinouts (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/p72-o2-sensor-wiring-diagram-1844789/) or B) get your ECU chipped to disable the heater.
