No VTEC on my ls/vtec HELP!!!!!
Old Sep 9, 2005 | 06:45 AM
hondaluva's Avatar
Default No VTEC on my ls/vtec HELP!!!!!
I just finished installing a b16 head on my stock ls block in my 96 integra rs. I'm using a stock obd2a gsr ecu and the car won't go into vtec. I've checked everything I can think of: the wiring the vtec solenoid vtec preesure switch oil pressure I don't know what this could be. When I give the vtec solenoid power straight from the battery it goes into vtec but it won't work from the ecu on its own. What the hell is going on here? I'm getting code for but i can't remeber which one, i'll go pull and post it up.
Old Sep 9, 2005 | 08:39 AM
TurboCoop's Avatar
Default Re: No VTEC on my ls/vtec HELP!!!!! (hondaluva)
Mine didnt work at first when I finished my LS/Vtec conversion, it turned out to be my ECU--- whered you get the ecu? You should convert to OBD1 and chip it anyway, it will run a lot better.
Old Sep 10, 2005 | 10:29 PM
hondaluva's Avatar
Default Re: No VTEC on my ls/vtec HELP!!!!! (TurboCoop)
I tried the obd1 conversion harness with hondata s100 and that kept throwing a vtec pressure swith code so we figured we would try a stock ecu and get everything working then tune it but its not working out. We know the switch is good but it just keeps throwing that code.WTF!! This was supposed to be a simple head swap now its turning out to the swap from hell!
Old Sep 11, 2005 | 09:36 AM
TurboCoop's Avatar
Old Sep 12, 2005 | 06:12 AM
hondaluva's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCoop &raquo;</TD></TR><TR><TD CLASS="quote">??? </TD></TR></TABLE>
Yep thats exactly where i am right now i might have to take it somewhere and get raped cause nobody seems to have an answer.
flipstylez86
Jul 15, 2010 07:52 PM
ericstypeR27
Dec 19, 2008 06:39 PM
technine
Jan 17, 2008 10:43 AM
Dc2 Joe
May 23, 2007 01:03 PM
rednec214
Dec 28, 2004 10:21 AM
