SRS failure?
Old Sep 8, 2005 | 06:49 AM
94CivicSi's Avatar
Default SRS failure?
posted in this EG/EK, but no one seems to have the answer.
Quick history, my SRS light came on at the same time my horn and cruise control stopped working. I assumed the cable reel was bad and replaced it. Now the horn and cruise work, but the SRS light remains on.
I'm getting SRS trouble codes 1-1, 9-2 and then again, 1-1. I've diagnosed 1-1 and the car is telling me I have an "open in the drivers airbag, replace". Diagnosis for 9-2 says that if the fuse for the SRS under the dash isn't blown, either the SRS unit or SRS main harness are bad. I need a "test harness" to determine which one.
Has anyone ever heard of a bad cable reel shorting out the entire SRS system? Is it possible? I have tried to clear the MES, but it won't erase. Anyone have any input or ideas short of replacing everything?
Old Sep 8, 2005 | 03:30 PM
Chiovnidca's Avatar
Default Re: SRS failure? (94CivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94CivicSi &raquo;</TD></TR><TR><TD CLASS="quote"> I have tried to clear the MES, but it won't erase. </TD></TR></TABLE>
The procedure for clearing srs codes with the mes connector is difficult. Are you sure your doing it correctly?
Old Sep 8, 2005 | 04:48 PM
94CivicSi's Avatar
Default Re: SRS failure? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">The procedure for clearing srs codes with the mes connector is difficult. Are you sure your doing it correctly?</TD></TR></TABLE>
I followed this procedure: http://www.norcalrcrew.com/index.php?categoryid=13
I never got past step 4 because my light would not shut off after 6 seconds. It continued to stay on. Do those instructions seem correct to you? They do not say that the service connector should be jumped. Should it?
Old Sep 9, 2005 | 05:04 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94CivicSi &raquo;</TD></TR><TR><TD CLASS="quote">/index.php?categoryid=13[/url]
I never got past step 4 because my light would not shut off after 6 seconds. </TD></TR></TABLE>
Are you jumping the mes connector or the service check connector? The mes is by the fuse box.
Old Sep 9, 2005 | 05:37 AM
94CivicSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Are you jumping the mes connector or the service check connector? The mes is by the fuse box.</TD></TR></TABLE>
MES connector. Yellow plug, grey/grey wires.
My question was, do I ALSO need to jump the service connector to reset the MES.
Old Sep 9, 2005 | 06:11 AM
Chiovnidca's Avatar
My question was, do I ALSO need to jump the service connector to reset the MES. </TD></TR></TABLE>
Nope
Old Sep 9, 2005 | 12:00 PM
94CivicSi's Avatar
Ok, I give up.
New question. If I buy a used SRS unit, can it be shipped or do I risk having UPS wreck the shock sensor?
Old Sep 9, 2005 | 07:37 PM
rainforest's Avatar
Default Re: (94CivicSi)
just replaced the cable reel and it will fix the other code...promise
Old Sep 10, 2005 | 06:07 AM
94CivicSi's Avatar
Default Re: (rainforest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest &raquo;</TD></TR><TR><TD CLASS="quote">just replaced the cable reel and it will fix the other code...promise</TD></TR></TABLE>
I have already replaced the cable reel.
Old Sep 12, 2005 | 07:25 AM
94CivicSi's Avatar
Gave up and took the car to the dealer this morning. You were right, this cable reel is ALSO bad.
Since I'm sitting on 3 broken ones now, I may pop one open and see if I can repair it. Anyone every tried that before?
blkgsr03
Jan 15, 2006 10:36 PM
klomast3r
Oct 5, 2005 09:48 PM
94CivicSi
Sep 7, 2005 11:00 PM
TougeToad
Jun 5, 2004 07:22 PM
theman-dlh
Audio / Security / Video
Sep 5, 2003 06:36 AM
