no VTEC ,,, help me
Old Sep 26, 2006 | 09:02 AM
  #26
slo_crx's Avatar
i dont have a sending unit at all jsut an electronic gauge.... could this be my mystery problem??? it kinda makes sense what do the rest of you think?
Old Sep 26, 2006 | 10:51 AM
  #27
si90rex's Avatar
Default Re: (slo_crx)
weird question but with a SOHC if the check engine is on does vtec engage, i know with a b-series it matter but don't know about a Sohc.
but to ur problem oilpump any good? oil pickup bent? my old electric gauge didn't work for crap. at WOT it just when past 100psi were it wasn't reading. and at idle it was at 0 psi. do u need a knock senor to run aem's program?
Old Sep 26, 2006 | 05:08 PM
  #28
slo_crx's Avatar
any one else think that it could be the oil pressure sending unit .. cuz i dont even have obne at all and i have some peole telling me it could be a problem and others saying it has nothing to do with it./
Old Sep 26, 2006 | 05:38 PM
  #29
slomofo's Avatar
GDD Member
LMA install gone bad.
It's happened to me before. Make sure the cam caps aren't backwards or in the wrong place, also make sure the cam rails are in the right place, take out your LMAs, inspect them and reinstall them, but before you tear into it, make sure your timing belt isn't the problem.
Old Sep 26, 2006 | 07:58 PM
  #30
slo_crx's Avatar
well truthfully the LMA's are the lst thing we replaced(with the springs and retainers) and also it was the last known time that vtec worked...(before install)) how exactly could they be in wrong .. what would i ahve to look for?
Old Sep 26, 2006 | 08:18 PM
  #31
slo_crx's Avatar
also with them being installed wrong ... that means vtec wouldnt work?,... thanks for all the info and help guys.
Old Sep 27, 2006 | 11:08 AM
  #32
slo_crx's Avatar
thanks everyone for all the help so far.. but i still need some of my questinos answered.. so ..bump
Old Sep 28, 2006 | 03:53 PM
  #33
slo_crx's Avatar
any more ideas.??? i think im gonna rip the head apart and check the lil rocker arm pins.... is there a way to check with out taking everything apart?
Old Sep 28, 2006 | 07:59 PM
  #34
slomofo's Avatar
GDD Member
Did you pull your rocker arms out when you changed your LMAs? You didn't have to.
Take your cams out, then flip your rocker arms up and make sure your LMA install goes perfectly this time, then pay attention to your cam caps/rails, if you install them backwards or the dowels are bent/smashed in, VTEC won't work.
Old Oct 7, 2006 | 10:10 AM
  #35
slo_crx's Avatar
no CEL's and yes i always let the car warm up
95gsr_integra
Apr 10, 2006 11:16 AM
Vtakkk
10
Mar 30, 2006 10:17 PM
crispydee
Sep 29, 2004 03:30 AM
