no vtec? help
Old Jan 17, 2002 | 07:23 PM
Kamin's Avatar
Default no vtec? help
Ooook
after much anguish and money i got the engine running reasonably well
but theres no vtec
i have already checked oil level, vtec solenoid wires, and ecu. whats next?
edit: jdm b16a second gen engine.
thanks
ALSO there is no working o2 sensor right now, could this cause the problem?
[Modified by KAMiN, 6:06 AM 1/18/2002]
Old Jan 17, 2002 | 07:28 PM
rainforest's Avatar
Default Re: no vtec? help (KAMiN)
vehical speed sensor. thats what it is whan you can find the problem.
Old Jan 17, 2002 | 07:31 PM
Dee's Avatar
Dee
Default Re: no vtec? help (rainforest)
is your speedo working?
Old Jan 17, 2002 | 08:06 PM
Kamin's Avatar
Default Re: no vtec? help (drealgsr)
yes spedo is working
ALSO THERE IS NO WORKING O2 SENSOR
can that cause the problem?
Old Jan 17, 2002 | 08:29 PM
FitCRX's Avatar
Just wait your car may have a mind of it's own like mine! I have had the b16 in there for a month...never had Vtec...once or twice I could hear a difference....Last week the car was over heating...at least the sensor said..I also started getting a code...code 17 ....the VSS. Speedometer works fine..so im guessing its the sensor. Today we replaced the fan relay..and fan temp sensor...made some adjustments on the timeing...runs beautiful...didn't change the VSS sensor and Im still getting that code. but the supriseing thing is..I got vtec now..I can hear it..and feel it...hopefully it stays...I've only had it for one day, and I spanked some *** with it..nor celica, mustang, or mercedes could keep up with me.
Old Jan 17, 2002 | 09:06 PM
Kamin's Avatar
Default Re: no vtec? help (FitCRX)
but im not getting a code (well i am but only for my non functioning o2 sensor)
everything else is hooked up and working. (so far)
Old Jan 17, 2002 | 10:01 PM
Dee's Avatar
Dee
I know this sounds stupid but did you let the car warm up properly before doing hard pull? Is the strainer screen for the spool valve clean? What weight oil are you using?
Old Jan 17, 2002 | 10:20 PM
Kamin's Avatar
yes fully warm 10w30 oil.
also, where is the strainer screen for the spool valve located? (im thinking of the one on the IACV)
im trying to get an answer, will the o2 sensor have anything to do with this? i mean when you hit vtec the air fuel mixture richens and the o2 sensor relays info like that, anyone?
[Modified by KAMiN, 7:21 AM 1/18/2002]
[Modified by KAMiN, 7:22 AM 1/18/2002]
Old Jan 17, 2002 | 11:37 PM
Dee's Avatar
Dee
The strainer is located between the head and the spool valve. My o2 isn't connected at all and VTEC stll screams like a virgin on the first night.
Old Jan 17, 2002 | 11:42 PM
Type Goch's Avatar
New User
if youre running a cat, try checking that. A guy I know lost a LOT of power when he had a clogged up cat.
Old Jan 18, 2002 | 05:47 PM
Kamin's Avatar
Default Re: no vtec? help (Type Goch)
im gonna check that screen tommrow
its probably that
the engine hasnt been started in over a year
stehigs321
15
Mar 1, 2019 05:16 PM
ej8parkd
Aug 7, 2009 07:05 AM
vicki
12
Oct 22, 2008 10:26 AM
Jon5240
May 11, 2006 07:22 PM
skimb37
Aug 26, 2003 04:11 PM
