needing to know some torque specs
Old Nov 4, 2003 | 07:10 AM
IH82LOSE's Avatar
Default needing to know some torque specs
i have a friend who is putting his motor back together its a 98 itr. he has a chilton manuel but it does not say the torque specs for the bolts on the main bearings and the rod bearings. if anyone can help on this we would really appreciate it
Old Nov 4, 2003 | 07:49 AM
Rtype16's Avatar
Default Re: needing to know some torque specs (IH82LOSE)
The bolts over the bearing cap bridge are 49 lbs/ft and the others are 56 lbs/ft.
Old Nov 4, 2003 | 08:25 AM
IH82LOSE's Avatar
Default Re: needing to know some torque specs (Rtype16)
how bout the bolts that are for the rod bearings
Old Nov 4, 2003 | 09:08 AM
IN VTEC's Avatar
Main caps you should step torque.
1st step = 22 lb*ft
2nd step = 49lb*ft (2,3,4) and 56 lb*ft (1,5)
Torque from inside-out.
For the rod bolts, it's highly recommended that you use a rod bolt stretch gauge and stretch the bolts .13mm to .15mm. If you don't care to buy a $150 stretch gauge from ARP (which is the one that I recommend using), then you can torque the rod bolts down to:
1st step = 14lb*ft
2nd step = 33lb*ft
Straight outta the Helm service manual.
Old Nov 4, 2003 | 07:53 PM
IH82LOSE's Avatar
Default Re: needing to know some torque specs (IN VTEC)
thanks guys i really appreciate it
N/A ALL DAY
Engine Management and Tuning
Apr 8, 2012 10:10 AM
eortizr
Aug 23, 2005 10:08 PM
eghonda
Nov 29, 2003 09:22 AM
magicwand
May 26, 2002 08:36 PM
