Need with problem around 7000 rpm
Old Jan 21, 2004 | 01:04 PM
SivikHatch's Avatar
Default Need with problem around 7000 rpm
I have a 92 civic hatchback with a b16a2 stock motor. When I'm in first and second gear around 7,000 RPM and up the car slows down and takes off(jerking feeling over and over) constantly until I shift into second gear. When I'm in second gear it has the same problem. What is going wrong? Third, fourth, and fifth gear is fine. I recently change my alternator if it helps.
Old Jan 21, 2004 | 01:35 PM
B18T_EGhatch's Avatar
Default Re: Need with problem around 7000 rpm (CantBeStopped)
the slows down and taking off sounds like ur misfiring but that would be happening in every gear most likely.... check ur plugs and ur distributor cap anyway. if not it could be ur trans
jrdc5r
Transmission & Drivetrain
Feb 19, 2019 10:57 AM
takeit
Sep 11, 2007 11:54 AM
integraboi1010
Mar 5, 2007 09:14 AM
peel17
Dec 6, 2005 03:01 PM
HONDA_TEG
Apr 21, 2005 10:47 AM
