what do u have to do to change my obd2 d16 to a obd1?
1 Post
Re: what do u have to do to change my obd2 d16 to a obd1? (h22_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22_crx »</TD></TR><TR><TD CLASS="quote">what do u have to do to change my obd2 d16 to a obd1?</TD></TR></TABLE> I believe you use a jumper harness.
sorry, i'm not doing anything for you. you need a conversion harness and a obd1 ecu. depending on the motor and trans you may have to do the IACV conversion.
search
search
yea, you need alot more than that. 1st which d16? you need a matching obd1 ECU, either chipped or non chiped. Chipped if your gonna tune, which is what OBD1 is for in the 1st place. Then you need the jumper harness. Then you need a basemap, or a base tune. You will need to get ahold of a tuning app like uberdata or chrome. If you wish to tune yourself, get a ugo WB02, Datalogging nokia data cable, and a laptop. Also you need a ROM burner. Otherwise im sure if you spend $$$ on a tuner, then can burn you a basemap/tune on a dyno. Its $$$$$$$
