NEED HELP!!! poormans type r
Old Jun 18, 2008 | 10:27 PM
blkteggy's Avatar
Default NEED HELP!!! poormans type r
Today my motor got put in and when started it would give a backfire and sound like its mis-firing checked the coil and the igniter in the dizzy and cylinder 1 and 2 have spark but they are not running, so im running on two cylinders.
-switched injectors with the two running cylinders, but still the same
-switched dizzy coil and igniter and nothing
does anyone know my problem or have ever ran into a situation like mine?
will be doing a comp. test tomorrow and checking if some thing is wrong with my clips to my injectors
TIA
Old Jun 19, 2008 | 11:10 AM
blkteggy's Avatar
Default Re: NEED HELP!!! poormans type r (blkteggy)
anyone know of anything or what?
Old Jun 19, 2008 | 11:44 AM
superfast666's Avatar
timing
Old Jun 19, 2008 | 12:11 PM
blkteggy's Avatar
Default Re: NEED HELP!!! poormans type r (superfast666)
timing is okay, its just cylinder 1 and 2 that are not being used, just cylinder 3 and 4 are only running
Old Jun 19, 2008 | 12:18 PM
DonF's Avatar
Adjust your valves.
Old Jun 19, 2008 | 03:20 PM
blkteggy's Avatar
Default Re: NEED HELP!!! poormans type r (DonF)
thank you.
anyone else got any suggestions??? TIA to all
Old Jun 19, 2008 | 04:55 PM
blkteggy's Avatar
the engine doesnt making a clicking noise so it cant be that
Old Jun 25, 2008 | 07:19 PM
blkteggy's Avatar
ok.....well here is bit of an update...
switched my spark plugs around and the car seems to run a little bit better but....still misfiring.
i bought some new plugs to see if i had foul plugs witch are ZEX.
-when i was removing the plugs there was fuel all over the plugs on the white top and on the threads of the plugs as well. anyone have suggestions???
why are the plugs saturated with gas???
what could this problem be???
CAN ANYONE HELP ME!!!!!!! TIA
please keep this at the top so i can get my car running right.
TwitchDa9
Aug 3, 2011 03:18 PM
lilshady6796
30
Jul 1, 2009 09:25 PM
lsvtechatch92
Jun 25, 2007 07:55 PM
Streetracer4life128
Jul 2, 2006 03:12 PM
gracedIntegra
Jun 8, 2005 07:34 PM
