need help have code 13 atmospheric pressure
Old Jan 29, 2009 | 07:56 AM
DA3's Avatar
DA3
Default need help have code 13 atmospheric pressure
as the title states i have a dtc 13 atmospheric pressure, the car idles from 900-2200 rapidly when im at idle i replaced the iacv and the fitv, i also checked for vacuum leaks found none. now i have the factory repair manual for the car and its states that there is a barometric sensor above the seatbelt comp on the pass. side kickpanel i have had the chance to take a look at it yet, but the in the repair manual it states that the baro sensor is built into the main ecu, i replaced the ecu still same code and idle, can anyone with some expertise help me in this problem, im a c-b tech at a toyota dealer and apparently noone can help me with this delima
TwiztidRob2646
Jun 19, 2015 09:09 PM
sirmugenpower
Oct 27, 2009 05:16 AM
Ricta
Jan 16, 2006 06:45 PM
crxsiperf
Feb 26, 2004 08:29 PM
NWPNOMORE
Apr 17, 2002 09:23 AM
