Need help.
Old Jul 8, 2004 | 02:59 PM
mike34655's Avatar
Default Need help.
I just recently put a turbo on my car and decided to remove my Crower 63402-2 camshafts. I am putting back in the OEM GSR camshafts. My question is, what do I tighten these bolts down to? Whats the specs on the big ones in the middle and what are the specs on the smaller ones on the left and right side of the head? Here is a picture of what I am talking about. I also have another question after the picture.
Can I run my car without any modification like HONDATA? I have it but I wont be able to get to the nearest dyno shop before my cousin paints my car. I have to drive like 20 minutes to get to my cousins shop. I have bigger injectors and everything is done except for hondata being installed and dynotuned.
Thanks for any answers you have.
Modified by mike34655 at 12:12 AM 7/9/2004
Modified by mike34655 at 12:13 AM 7/9/2004
Old Jul 8, 2004 | 03:16 PM
mattssi's Avatar
Default Re: Need help. (mike34655)
You will need to run something other than a stock ecu map. Either that or use a fmu to get you there! unless you dont plan on revving over like 2500 rpm's. you don't want to lean out and cause engine damage. Try having it towed ?
Old Jul 8, 2004 | 11:15 PM
TECH43 RACING INC.'s Avatar
Default Re: Need help. (mattssi)
cam cap bolts: 20 ft lbs.
and yeah, what he said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">You will need to run something other than a stock ecu map. Either that or use a fmu to get you there! unless you dont plan on revving over like 2500 rpm's. you don't want to lean out and cause engine damage. Try having it towed ? </TD></TR></TABLE>
Old Jul 9, 2004 | 07:13 AM
mmuller's Avatar
Mad Scientist
Default Re: Need help. (TECH43 RACING INC.)
8x1.25mm bolts: 20ft/lb
6x1.0mm bolts: 7.2 ft/lb
Old Jul 9, 2004 | 02:12 PM
mike34655's Avatar
Thanks
laziebun
Sep 5, 2007 04:31 PM
eag36
Apr 19, 2005 07:50 PM
dunkd
Mar 3, 2004 11:49 AM
*Boostwerks*
Jan 13, 2004 10:39 AM
jamal-188
May 5, 2002 08:11 PM
