Oil leak question???
Old Aug 5, 2002 | 03:47 AM
zerofighter777's Avatar
Default Oil leak question???
Heres the deal. My mechanic put all new oem honda gaskets in my b16a before I did my swap. After I did my swap, I noticed alittle oil leaking out from the corner of the head near/under the v-tec soielnoid. It only leaks when I drive the car and is not that much. What could be causing this? Is the head not torqued down right/enough? Thanks in advanced.
[Modified by zerofighter777, 6:47 AM 8/5/2002]
Old Aug 5, 2002 | 06:54 AM
Crazydave's Avatar
Default Re: Oil leak question??? (zerofighter777)
bad seal it's easy to get to .. take it off and re-seal it..
oil should *not* be leaking from anywhere
Old Aug 5, 2002 | 07:21 AM
WOTTEG's Avatar
Acura Techs left tha same situation in my car after doing the valve specs. Leaks over by the grounding wire. Just enough to leave a little "residue" seep in the area.
I'll have to bust out the helm's and see what to do to seal it properly. . . . .
Old Aug 20, 2002 | 11:01 AM
Default Re: Oil leak question??? (WOTTEG)
Checked all seal and I found the spot where the oil is leaking. its between the head and th eblock. heres a pic. try the link if it does not work.
http://www.geocities.com/zerofighter777/oilleak.html
[Modified by zerofighter777, 2:03 PM 8/20/2002]
Old Aug 20, 2002 | 11:59 AM
keithv's Avatar
usually that means a bad headgasket...
Old Aug 20, 2002 | 12:14 PM
W.Zero's Avatar
it could be a couple things a bad headgasket but you said you change it with a new one right? or did you take off the vtec soilenoid and put it back on? if so then you need honda bond as the gasket to put the soilenoid back on or it will leak. since its leaks only under the vtec. check the to see if the leak is comming from vtec
Old Aug 20, 2002 | 01:49 PM
Chubz's Avatar
i have the same problem, its not coming from the block or head its the VTEC solonoid, bad gasket..needs a new gasket and honda bond
MoreCowbell
Apr 24, 2012 01:24 AM
apexrift
Jan 28, 2005 11:04 AM
2k2silvertype-s
Dec 20, 2002 07:04 AM
Vanilla4215
Oct 16, 2002 12:19 PM
Kasper.
11
Aug 28, 2002 07:48 AM
