Damn Earl fittings!
Damn Earl fittings!
I think I'm retarded or something because I can't seem to figure out how to connect the fittings on the hose Can someone give me some easy to follow directions
[Modified by B18Flip, 7:20 PM 3/31/2003]
Re: Damn Earl fittings! (B18Flip)
ok i see u have it taped.. good
1st u wrap that **** really tight with some tape.. electrical is nice.. duct tape works too. btw u just tape were u are gonna cut.
2nd.. cut the bastard with a air cutter... they work really good. or a dremel with a cutting tool.. they say u can use a hacksaw but i wouldnt.
3rd.. remove tape... be carefull. u sually i use 1 layer on.
then put the red end into a vise.. if u dont have put on a flat surface.. then put the hose directly down.. 90 degree angle..
should go on..
then pull the hose out about 1/8 an inch..
then take a pen like a sharpie felt tip.. and mark it.. u do this so when u tighen the fitting up u can see if the hose is being pushed out.. thats it your done..
should go on..
Re: Damn Earl fittings! (BoostedH23a1)
BoostedH23 you're the man! i figured something was supposed to be cut . I've been sitting here for like 30 min trying to stuff the whole thing in the red flange..lol thanks!
HT's Biggest Loser
Re: Damn Earl fittings! (1bar)
lol im just having a hard time gettin the hose into the red sleeve ..its a bitch
oops just saw your thread, same exact thing
are u having a hard time gettin the hose into the sleeve?
you can never get your hose into enough sleeves in one lifetime...newest ht quote!
T-RO
02-24-2004 08:44 PM
