Is this my clutch slipping??
Old Aug 7, 2004 | 02:16 PM
InLimbo87's Avatar
Default Is this my clutch slipping??
Alright ive got this weird problem. I have a turbo integra ls, stock clutch (only been turbo for a couple weeks). Today it was driving and everythin was fine and dandy. i did drive around a lot though. Then later on, everytime i got over like 5500 in boost it would stutter a little and then rev up real fast while i was still in gear, is this the clutch dying out on me or some other problem?? I was thinking it may be the clutch because i have heard that a warm clutch is more prone to slipping. any opinions?
Old Aug 7, 2004 | 02:19 PM
InLimbo87's Avatar
Default Re: Is this my clutch slipping?? (tegsedan)
could it be an injector leak also?
Old Aug 7, 2004 | 02:20 PM
InLimbo87's Avatar
how about a fuel pump?
Old Aug 7, 2004 | 03:21 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegsedan &raquo;</TD></TR><TR><TD CLASS="quote"> Then later on, everytime i got over like 5500 in boost it would stutter a little and then rev up real fast while i was still in gear, is this the clutch dying out on me or some other problem?? </TD></TR></TABLE>
Sounds like you making to much power. Time to upgrade the clutch.
Old Aug 7, 2004 | 03:24 PM
InLimbo87's Avatar
Default Re: Is this my clutch slipping?? (Chiovnidca)
so that stuttering im talkin about while in gear (didnt touch pedal) is still the clutch slipping???
Old Aug 7, 2004 | 03:27 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegsedan &raquo;</TD></TR><TR><TD CLASS="quote">so that stuttering im talkin about while in gear (didnt touch pedal) is still the clutch slipping???</TD></TR></TABLE>
Could be the clutch trying to hold it together and not having any luck (a little chatter maybe) so it just lets loose. Your going to have to determine that for sure though, my crystal ball is out for repair.
Old Aug 7, 2004 | 05:23 PM
murtnabila's Avatar
the clutch is the weak point between the engine and tranny. It's supposed to give out hopefully b4 any damage to tranny and motor. But you are no longer stock, you need to upgrade the clutch whether or not that is the problem. Though I believe that it is the problem.
Old Aug 7, 2004 | 06:46 PM
DC2EATER's Avatar
Default Re: Is this my clutch slipping?? (murtnabila)
Did it feel like the power dropped when it revved quickly, or did it still accelerate after the studdering? If it felt like your acceleration dropped off while the engine was continuing to rev then your clutch is probably slipping, and it is more likely to happen when it is hot, and especially on the stock clutch on the amount of power you're making. Stock clutch won't last long at 10lbs of boost especially with your 110,000 miles already on it . If your car continued to accelerate just as strong after the studder then the problem is probably with the fuel management.
Old Aug 7, 2004 | 06:55 PM
InLimbo87's Avatar
Default Re: Is this my clutch slipping?? (DC2EATER)
it feels kinda like a misfire, and then my clutch slips too if that makes any sense. hah, well we will see how long your 174,000 mile clutch lasts then.
Old Aug 7, 2004 | 06:57 PM
DC2EATER's Avatar
Mine was changed at 150,000 ... and the car now has 182,000 just to update you
Old Aug 7, 2004 | 08:47 PM
InLimbo87's Avatar
im pretty certain it may be leaking injectors. i reused the old seals and may have overbored one or two, and it seems like they are making a little stain on the im. Ahh now ive gotta replace them and i think im gonna gap my plugs to .030". will update after both have been done.
Old Aug 7, 2004 | 08:52 PM
InLimbo87's Avatar
just checked and yup. theres a stain underneath one of the injectors. I thought i could get away w/o an o-ring that i broke, ooops!!! Anyone know if you can just buy the o-ring from napa or somewhere, im a cheap bastard?
TigerLy
Jul 16, 2008 01:59 PM
zach1288
16
May 9, 2007 05:57 AM
KrispyKreme
22
Jan 10, 2005 11:57 PM
cinq
Mar 26, 2004 11:30 AM
