Help on oil seal removal
Old Dec 27, 2003 | 08:46 PM
david90's Avatar
Default Help on oil seal removal
So far I got everything out and is looking at the crank oil seal. I tried to get a hook type tool to hook on the seal and pull it out but the surface is too hard and my tool doesn't go in deep enogh. I tried to put a screw into the seal and pull it out but once again because the oil seal is hard, the screw did not went thru. How does the dealer remove the seal? what tool do they use?
is it ok to use a flat head and jam between the bore and the outside diameter of seal and pry it open? won't that scratch the bore through? I need tips! Is there a tool i can get?
see pic below
Modified by david90 at 11:28 PM 12/28/2003
Modified by david90 at 11:29 PM 12/28/2003
Modified by david90 at 11:36 PM 12/28/2003
Old Dec 28, 2003 | 01:27 PM
david90's Avatar
Default Re: Help on oil seal removal (david90)
bump bump. Help....I can't get my front crank oil seal out. My seal is flush with the block and it fits so suggly that I have to really put force into my flat head and I don't want to scratch my seal. I need all the help I can get.
Old Dec 28, 2003 | 06:04 PM
tvrsir's Avatar
drill a lil hole in the ring and use a screw screw it in and use a vise grip to pull on the ring. you migh have to drill another one 180 degree opposite and do the same take a lil time but that shoudl do it
Old Dec 28, 2003 | 06:11 PM
david90's Avatar
while using a flathead to pry out the seal from the inner diameter, i notice that there is a metallic material shows when the rubber flew out. Does this metallic material belong to the seal or the engine? If it is the seal then I was doing it all wrong because I didn't want to scratch it thinking it is part of the bore. I tried to avoid it.
Old Dec 28, 2003 | 06:22 PM
RCautoworks's Avatar
Default Re: (david90)
Why not just get a seal puller ?
Old Dec 29, 2003 | 03:40 PM
tvrsir's Avatar
it's part of the seal. don't worry. also you will find there a spring like ring too. that all comes with the new one.
Old Dec 29, 2003 | 06:43 PM
mmuller's Avatar
Mad Scientist
Default Re: (tvrsir)
I would just take the oil pump out, makes the job a lot easier
budomove
Apr 18, 2009 09:00 AM
mattbatson
Mar 30, 2009 07:23 PM
imtrill
Sep 29, 2006 03:35 PM
PopeyeTheSailorMan
Aug 5, 2003 02:16 PM
