manual tranny fluid vs. motor oil
some peeps say use gear oil... guys at the shops and dealer say use motor oil... wat do u use in ur tranny gear oils. whats is better and will last longer. let me know thanks.
Re: manual tranny fluid vs. motor oil (wizzards581)
with people i have helped
in a general practice motor oil works fine, but if you are STARTING to get a grind or hard shift, immediatley switch to honda MTF.
ive seen it completley fix small grinds and hard shifts.
the reason i say use motor oil first, is MTf is anywhere from 10-15$ for 2 quarts. motor oil is 6$ for 2. 10w-30 works fine.
Re: manual tranny fluid vs. motor oil (Spoon)
yeah, i use Mobil Oil now, but I am planning to switch to Honda MTF this weekend....the regular Mobil oil just doesn't seem to cut it with the really quick shifts (I seem to get small grinds....)
Re: manual tranny fluid vs. motor oil (tnbigdawg)
I'm using redline mt-90. Switching to redline mtl soon. Before that I used honda mtf. I wouldn't recommend that anyone use motor oil.
Yeah, I know that redline mtl is more expensive than some of the other stuff, but $7/qt. vs $4/qt doesn't make a difference when you only need 2 qts once a year.
Re: manual tranny fluid vs. motor oil (Kamin)
Re: manual tranny fluid vs. motor oil (clm)
I can attest to that. I had grinds in 2, 3, and 4 and after about a week of having changed the fluid, they were all gone. Go for Honda MTF. "Do it once, do it right."
enoker001
Transmission & Drivetrain
06-25-2009 11:09 PM
