Missing parts in 3stage vtec
Old Jun 16, 2016 | 01:29 PM
komet 163's Avatar
Default Missing parts in 3stage vtec
hello ....HONDA WORLD
i need some help in my D15BZ7 aka 3stage vtec OBD2a...
where it goes the hose coming from there
someone has a photo of the part...
That would help me a lot, Somebody told me it's a kind of vacuum solenoid but I dont even know, I didn't come when I bought the swap
thanks
Old Jun 16, 2016 | 01:46 PM
2kdrift's Avatar
Default Re: Missing parts in 3stage vtec
needs to be hooked up to a vacuum source, its just a egr valve anyway nothing to do with your vtec
also you got the engine code wrong is a d15z7
Old Jun 17, 2016 | 06:38 PM
v4lu3s's Avatar
RTFM
not just a vacuum source but one with an egr control solenoid on it as well. that solenoid has to be wired up to work with the ecu, and unles you have a civic vx, or hx you probably have to custom wire it.
Old Jun 19, 2016 | 03:47 AM
HondaPartsHero's Avatar
Technical Hero
What ECU are you running?
Old Jun 20, 2016 | 06:21 PM
komet 163's Avatar
Im runnin a P2J-J62 stock ecu
Old Jul 2, 2016 | 05:22 PM
komet 163's Avatar
Nobody?
Old Jul 3, 2016 | 02:11 AM
holmesnmanny's Avatar
Did you look at his illustration, that's the egr valve. It goes to the egr solenoid and the egr solenoid also goes to the vacuum control device(the egr solenoid has two nipples).
You could just unplug the egr valve connector there and other than throwing a code it won't affect anything vtec-wise.
Old Jul 5, 2016 | 01:47 PM
tony_2018's Avatar
Fish Twig
You're missing the egr control solenoid. The egr's vacuum source connects to the control solenoid and the solenoid gets connected to a vacuum source. Also you might not be able to use the j62 because its an automatic cvt ecu.
Jdmb16a_integra
Jan 2, 2012 09:21 PM
GSRHATCH619
12
Apr 2, 2008 03:48 PM
agiorlando
28
May 14, 2007 06:08 PM
RandomTask76
May 20, 2003 05:19 PM
satan_srv
Dec 20, 2002 10:23 AM
