Swapped Da, need help with ecu codes!
Old Jan 2, 2012 | 07:01 PM
Jdmb16a_integra's Avatar
Post Swapped Da, need help with ecu codes!
I have a 1990 acura integra da special edition with a jdm b16a i swapped in,
I went to the junk yard and got me ecu pins to wire in knock, vtec and pressure switch.
Its all wired up right and I have proper grounds, but im throwing a ecu code 14 and 21.. 14 is IAC valve and 21 is Front VTEC Solenoid Valve.
Does anyone have a clue how I can fix these and get VTEC to engage?
Old Jan 2, 2012 | 07:37 PM
standy xsi's Avatar
Default Re: Swapped Da, need help with ecu codes!
theres a thread on here how to clean both.... mayb thats a start? yo
Old Jan 2, 2012 | 08:01 PM
do u know what the thread is called by any chance bro?? and thanks for pointing me in a direction that might help!
Old Jan 2, 2012 | 08:11 PM
standy xsi's Avatar
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
theres the IAC, awsome as has alot of pics
the vtec solanoid one is on here somewhere. have you had it open before?
sometime's the gorse gets cloged an im havn a blank atm but the little valve on top gets stuck aswell (cant membah the lil buggers name)
but thats where i would start,
if that doesnt work grab your trusty multimeter and chech what voltage and resistence you are geting. cant remember off hand what it is, but search an you shall find
Old Jan 2, 2012 | 09:21 PM
el crapitan's Avatar
could try putting 12volts to the solenoid directly. see if it clicks
resistance should read around 15ohms, i believe
RB_EJ8
Aug 6, 2008 03:56 PM
agiorlando
28
May 14, 2007 06:08 PM
type Gendy
20
Mar 10, 2005 07:00 PM
shaddr3
Apr 12, 2004 12:33 PM
satan_srv
Dec 20, 2002 10:23 AM
