melted piston and chipped sleeve?????? what to do
Old Jun 21, 2005 | 01:07 PM
98 blacksh's Avatar
Default melted piston and chipped sleeve?????? what to do
i just recently melted my 4th cylinder piston on one of the edges, and i somehow put a good size chip in the cylinder wall, i dont know if i can bore it and put oversize rings in i just want to get it running so that i can sell it any help on what i could do its a type sh so i want to just buy a new block but youcant realy find them please HELP
Old Jun 21, 2005 | 04:51 PM
98 blacksh's Avatar
Default Re: melted piston and chipped sleeve?????? what to do (98 blacksh)
up need help now
Old Jun 21, 2005 | 06:20 PM
slomofo's Avatar
GDD Member
If the damage isn't very serious and you can overbore, then you have to replace all four pistons and bore out all four cylinders.
If the damage is too serious, then you have to re-sleeve it and replace the one piston.
If you pull the pistons out and find that the bad piston has ruined the rod or the crank, then you'll have to replace that as well.
Either way, you're screwed.
da_rimrocka
Nov 30, 2005 12:14 PM
BigGreenAuto
Oct 15, 2005 02:59 AM
ludelvr
Nov 26, 2003 03:56 PM
SupaFly_Honda
Jan 21, 2003 06:53 AM
