Maximum horsepower?
Old Jun 11, 2003 | 08:15 PM
1hotvtec's Avatar
Default Maximum horsepower?
I have a 02 vw gti 337 with the 1.8T engine in it. The question is what is the max horsepower I can get out of my setup with out replacing piston, rods, ect... I currently have a boost controller, cat back exhaust, and cold air intake. My last question is what type of hps am I making if I turn up my controller to 14lbs of boost if my car normally gets 180hps.
Old Jun 11, 2003 | 08:28 PM
irev210's Avatar
Default Re: Maximum horsepower? (SPOONCIVIC_97)
vw-tech might know
Old Jun 11, 2003 | 08:33 PM
tilt's Avatar
you just wasted my time.
Old Jun 11, 2003 | 08:46 PM
1hotvtec's Avatar
Default Re: Maximum horsepower? (tilt)
What didi you mean waste your time? My ride will smoke your car any time! I am just curious as to what type of internals I will have to do. You did not have to reply if you did not want to!
Old Jun 11, 2003 | 11:08 PM
00b16's Avatar
Doesn't matter if you can smoke anyone, you are asking about vws on HONDA-TECH. As for your question, as far as I know those engines will handle nearly 20psi with stock internals. With the right tuning 300 should be easy. However, high hp number doesn't mean anything. You have to get that to the ground .
EDIT:You will need a quite a few more things, front mount intercooler, tuning method, etc...
Old Jun 12, 2003 | 08:06 AM
JimBlake's Avatar
Default Re: Maximum horsepower? (irev210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">vw-tech might know
or http://www.vwvortex.com
Old Jun 12, 2003 | 08:44 AM
sslude's Avatar
Default Re: Maximum horsepower? (JimBlake)
you're asking HONDA-tech, and you drive a VW, but then again your user name is spoon civic...
Old Jun 12, 2003 | 08:48 AM
GSRwBOOST's Avatar
DJaeMac
Honda Civic (2001 - 2005)
10
Sep 27, 2007 10:27 AM
Manny86
Jul 3, 2007 05:29 PM
clutch6racerone
May 29, 2007 11:17 AM
Integra21
Apr 20, 2006 06:25 PM
tr123gone
Feb 16, 2005 08:29 PM
