MAP sensor values
I have a Denso 5V-PS-33 Map Sensor and want to know what the voltage readings will be versur vacuum and boost. All I know about the sensor is the Yellow with red stripe is 5 volts, green with white stripe is ground and signal is on the green with red stripe.
I assume 2.5 volts is atmosphere, 5 volt is 11 psi and 30 inches of vacuum is 0 volts. I will aprreaciate any information I can get.
Thanks
Jack
PS I am using this to measure boost in a non Honda vehicle.
Thanks
Jack
eg:R
Oct 23, 2005 01:54 PM
