Main Shaft Bearing...
Old Aug 20, 2004 | 11:52 PM
crzyfool24's Avatar
Default Main Shaft Bearing...
Ok, I just spent the last hour or so trying to get some info on the Mainshaft Bearing, Pilot Bearing and T/O bearing. I learned A LOT about these bearing of what they do and what could go wrong with them. My main concern is the mainshaft bearing. I read that it is not a pressed bearing. Is this correct? So if I was to replace the bearing, would it come right out or what?
Also the pilot bearing. I was reading that it is kinda hard to get in. People were using a wood block and a hammer to pound it in. Well, if its so hard to get in....How would I take it out? Could I find these bearing at Auto Zone or some local parts shop? Thanks for the help!!
Old Aug 21, 2004 | 12:22 AM
N2O's Avatar
N2O
Default Re: Main Shaft Bearing... (crzyfool24)
If you are talking about a B series trans, which main shaft bearing are you talking about. Neither the front nor the back one are pressed on. I am sure you can get these at a parts store however I would order them from Honda. As for your pilot bearing lay the flywheel across a couple of 2x4s so that nothing is under the pilot. Find a socket that is about the same size as the outer part of the bearing and pound it out.
Old Aug 21, 2004 | 03:09 AM
EE_Chris's Avatar
Default Re: Main Shaft Bearing... (N2O)
Find the bearings at slhondaparts.com or the like.
Throw the pilot bearing in the freezer the night before for an easier installation. I just use a socket around the same size as the outter race of the bearing, instead of a block wood.
The two bearings on the mainshaft are not pressed in - very easy to replace (input shaft bearing requires removal of the whole gear cluster though).
parahelium
Transmission & Drivetrain
Jun 8, 2017 10:46 AM
prelude182
Aug 3, 2009 05:53 PM
del_slow420
Sep 24, 2007 06:32 AM
SlowPokeEg
Sep 23, 2006 01:49 PM
crzyfool24
Aug 31, 2004 04:59 AM
