ls/vtec question? speak from experience please
Old Sep 22, 2002 | 10:53 PM
junya16's Avatar
Default ls/vtec question? speak from experience please
i am about to install an ls vtec in my car and i'm debating whether to balance and blueprint my block with the pistons and rods in it or just balance to the crank. i don't know what to do. if you have this setup what did you do to your block if anything and how is it working out? i know it's a pretty vague question but help me out guys.
thanks
Old Sep 22, 2002 | 11:23 PM
riceboy's Avatar
Default Re: ls/vtec question? speak from experience please (junya16)
Balance the crank, flywheel, and harmonic balancer together. Then assemble the block.
Old Sep 23, 2002 | 04:08 PM
Kataku2K3's Avatar
Default Re: ls/vtec question? speak from experience please (riceboy)
i would atleast go .25 over with PR3 or P30 pistons, you will have a c/r or 11.4-11.6:1 with a PR3 head. GSR head and CTR pistons will raise it more. I hate stock bottom end LSVTEC's my friends runs a 13.5 in his EG which is okay but nothing special.
Old Sep 23, 2002 | 04:33 PM
ImportReview
Guest
Posts: n/a
If your not going to rev over like 8k...
You don't need to do anything.
Jeff
Old Sep 25, 2002 | 01:33 PM
nickb20vtec's Avatar
i've had 3 ls/vtec and all of them have blown with NOS! it was my fault! if the motor was built correctly! it should be very strong! the last one i've had was with je pistons, eagle rods and rings, ran strong for a good 6 months untill i blew with a 100 shot! but my friends have the same set up! and they havent even had one problem yet, its been almost 2 years now!.
Old Sep 25, 2002 | 01:45 PM
X2BOARD's Avatar
Default Re: ls/vtec question? speak from experience please (nickb20vtec)
What fuel did you use.... system that is...
If you rev to 8+, balance and blueprint if you can afford it. If you are using aftermarket pistons/rods, they are commonly already balanced within a gram, but I did the whole assembly to make sure. Pistons, rods, crank, flywheel, pressure plate at 7-8K, smooth as Britney's ***....
X2
Old Sep 25, 2002 | 09:11 PM
junya16's Avatar
Default Re: ls/vtec question? speak from experience please (X2BOARD)
thanks guys i think am i actually going to go with a gsr block instead of the ls/vtec because for the cost of the balance and blueprinting of the ls block i can get a gsr block. think i'm gonna go the reliability route.
Old Sep 26, 2002 | 12:45 AM
Quik Chris's Avatar
Yeah, that's the way to go. I'd get PCT Civic R pistons in there. That would be a nice set-up. I had 25 over PCT pistons in my LS/VTEC (GSR head). Had to put 101 in that biatch all the time. Fun motor though. Shame the head gasket and clutch went bad. 12.98:1 CR is cool. Won't be that high in a GS-R block though.
Old Sep 26, 2002 | 04:56 PM
my first ls/vtec was stock bottom end, with a type R head. fuel and everything was stock! i was able to rev up to 8500rpm and up to 88 on track days. oh wait i also had crower springs.
AmbiguousCivic
Jun 10, 2007 11:10 AM
dohdoh420
Apr 18, 2006 11:46 AM
Shiro Z31-T
Feb 12, 2005 02:46 PM
Triple T
Jan 28, 2003 09:31 AM
dub204
Jul 2, 2002 04:29 PM
