ls/vtec piston question
Old Mar 21, 2005 | 01:04 PM
saleensolution's Avatar
Default ls/vtec piston question
im putting together a ls/vtec turbo set up. i contacted arias pistons (they were not friendly at all) and they say to run a ls piston. cp pistons says to run a gsr piston................................which do i use? i know that on a ls head the intake and exhaust valves are the same size, and on the gsr the intake valve is 2mm bigger. i really dont want to have to fly cut the piston i just want to order the right piston. any knowledge would be helpful thanks
Old Mar 21, 2005 | 06:05 PM
NJIN BUILDR's Avatar
Default Re: ls/vtec piston question (saleensolution)
What compression ratio are you looking for?
Glenn
Old Mar 21, 2005 | 06:06 PM
Default Re: ls/vtec piston question (NJIN BUILDR)
im lookin for a 9:0.1 compression
Old Mar 21, 2005 | 06:21 PM
All of the aftermarket 9:1 turbo pistons will work for you.They all make the valve pockets larger than the vtec valves.
Glenn
Old Apr 14, 2005 | 07:33 AM
zCivic's Avatar
What bore are you using?? Thats the main thing. CP makes shelfed pistons for ls-vtecs but there 84mm+ bore for all motor, anything below they list for LS or GS-R arias just lists for the exact engine no matter the bore. Should have stayed all motor
Griffin@Camtech
Feb 22, 2006 06:15 PM
saleensolution
Mar 23, 2005 11:17 AM
saleensolution
Mar 22, 2005 01:49 PM
speeddave
Nov 3, 2003 08:16 PM
555R
Apr 10, 2002 03:57 PM
